Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
See more
See less
Tohatsu Hour Meter
  • Tohatsu Hour Meter
    I have a new 50TLDI tiller and want to put an hour meter on the motor
    I have the service manual and from what I can see I need to hook into a blue wire on the motor
    Can the Tohatsu guru's confirm this is correct please
    Thanks for any help
    Re: Tohatsu Hour Meter
    The ECU already records hours, so for service data, you already have the information available.
    Paul
    Buffalo NY USA
    • #3
      Thanks for the reply pvanv
      How do I access this data, The engine has no gauges attached
      I do have the three lights on the tiller handle, Can the data be accessed by use of those or is there some kind of plug in reader I can buy?
      • #4
        To get to the ECU data, you need to enter diagnostic mode. The procedure is in the Factory service manual.
        In order to read all of the data, you will need a Factory TLDI tachometer.
        If you have an aftermarket 12v (glorified clock type) hour meter, and just want to keep an eye on hours to schedule service, you can do that by turning the meter "on" with the lead that energizes the ECU. Then the hour meter will run any time the key is "on", even if the motor is not running.
        The complete wiring diagram and information concerning each individual wire is in the Factory service manual, available at any Tohatsu dealer.
        Paul
        Buffalo NY USA
        • #5
          That is the type I am getting, aftermarket 12v (glorified clock type)
          I have the factory service manual already
          I found the wire I need to hook into in the tiller handle control box, Brown wire activates 12 volt on ignition so I will use that
          Thanks for all help
