turbowhine
- May 1, 2010
- 1
Hello, I've been having some cooling issues with a new-to-me Tohatsu M3.5B2, which is a 2-stroke. I've got the propeller unit out of the lower case and after removing the two bolts holding the lower unit on, the gear case will drop about one inch but will not come free. Engaging and disengaging the neutral/gear lever will move the whole inner shaft up and down. I don't want to yank on it, but I'm wondering what I'm missing that will allow the gear case to come free of the shaft. Should I remove the bevel gear? I'm trying to access the water impeller to change it out... Any tips would be greatly appreciated. Thanks
