I have a 27' Edgewater with twin 225 honda motors with Seastar hydrolic steering. I have replaced a few hoses on the system and completed the bleeding as per the specs given. The issue i am having is that when i turn the wheel all the way to the starboard side the piston extends fully, when i attemp to turn to port, the cylinder does not extend all the way. It has almost two more inches of the cylinder left exposed. My second issue is it takes over eight full turns to turn from one side to the other. Like i said i did the bleeding to the specs and no air is coming from the bleeders. Do you think it is the same problem or two different issues?
