hello all, need some help/advice with my engine. the symptoms are, the engine will start and idle smoothly and the revs will increase smoothly using the fast idle lever. upon leaving the pontoon the boat will run good but only for about 5 mins it will then start to miss and starts surging , at this point i have to throttle back and slowly limp back . back at the pontoon the engine runs rough even in neutral and will sometimes stall completely .
Work i have done: cleaned tank, new fuel line tank to engine, new lp fuel filter, cleaned vapour sep tank, replaced screen under hp fuel pump, replaced fuel filter in vapour sep. compression check all @150-160 psi. have tried different tank and bulb. tank vent is not blocked.
At first i thought it could be a fuel issue but now i really do not know, maybe something goes wrong when the engine gets warmer, ht leads/coils ,i dont know , i am starting to get abit down, can anyone shed some light or give me some ideas of what to do next.
Thankyou all.
Thankyou all.
