My Honda four stroke runs fine in the driveway but on the water test it dies as soon as I push it past idle (Under Load) My guess is a fuel issue, I cleaned the carbs today did not see any obvious issues. Checked the fuel filter, lines, fuel pick up and changer the plugs. Compression test results were 80/75/80 by just turning the key over. I have read that the compression on 4 strokes are measured at wot, does the motor have to be running on 2 cylinders to check it that way ? Can I test my fuel pump without a pressure tester ? Any answers would help. I want to check as much as I can before I test it again Saturday.
