hi, i have a tohatsu 50HP tiller two stroke and id like to install a fuel/water seperator. i purchased a run of the mill filter setup where the filter is called "mercury style". will this type of filter work for my system? my filter is similar to this one:
http://www.iboats.com/Mallory-Filte...0799536--**********.134797787--view_id.365310
the housing has 5 holes. 4 with arrows going different directions and one hole pointing down. how does this setup work? im assuming that you come in one side and out the other with both arrows pointing the same direction but is there more to it? thanks for your help, mark
