hello all, i have a 2006 115hp fuel injected honda outboard. the engine will start well and idle smoothly, after idling for 5 mins i motor out from the dock and accelerate , the motor picks up smoothly and runs good,however after a few short deceleration/acceleration runs the engine starts to miss and eventually will cough alittle and stall unless i ease back on the throttle. i then have to limp back to the dock, the motor will now have a rough idle whereas before the idle was smooth. my thoughts -it seems that when the motor is warmed up it starts having problems ,is there a sensor that adjusts the timing as the motor heats up? or a fuel problem that becomes apparent after 5 mins. i have new fuel lines,filter,bulb and clean fuel. how do i check the injector fuel rail pressure? thanks for any input ben
