Commando C2
- Oct 3, 2009
- 80
Hello all
I have a 25hp tohatsu 2000 model 2 stroke.
she makes quite a clanking noise going into gear. reverse worse than forward.
once in it is gear it is fine but the noise sounds like metal against metal.
I got the engine out today and it leaked some watery/oily gunge from the prop /skeg area so i suspect there is a gear oil leak unless it is an over rich mixture from the exhanust. Pic of the leak attached.
I undid the top oil screw when the engine was upright on its trolley.
No oil seeped out, should it have?
What is the best way to change it, lye the motor on its side or do it in the upright position?
I am going to measure how much comes out so i know if it was low or not.
I took off the prop and the spline nut was not very tight at all, the prop could move about 3-4 mm on the spline. What is the tolerance here?
Also the seal around where the spline shaft goes into the gearbox housing was rusty and corroded but didnt seem to be leaking when inspecting it ( i had just run it so it had been wet)
Can someone direct me to a site to get the exact part no for these seals and also the seal on the oil filler screws as these seem to be constantly oily
I suspect the oil level is low hence the clanking into gear noise.
If its not low then i have a more serious problem
