Topstitcher
- Feb 28, 2010
- 1
I acquired a Nissan 140 from a mechanic lein auction. Opened the engine, clean!! However someone pilfered, or removed the oil resevoir from it. Not a big deal, I would rather mix the oil in the fuel. Problem is the engine "thinks" it is out of oil and shuts down. Safety device, I know. Since there is no longer an oil level sensing unit present, and it has been electrically unplugged, how do I tell the Multi-purpose Meter that there is not a problem and keep the engine running? Am I ok to run the two wires which attached to the sensor to each other creating a ground and making the motor think it is full of oil? Or is there something else I can try. Any help would be appreciated. Not made of money and the only certified Nissan Mechanic center is too far away.
Lynn
Lynn
