Re: 5 Horse Tohatsu short to long shaft conversion
Hey,
If the parts are the same, I will make you a trade, or depending on the wear, an engine to engine trade. My engine has about 15 hours on it. Anyway, maybe all we will be out it an atrocious amount in shipping. I have a 2006 6hp 4 stroke Nissan that is either long or extra long shaft. I wish I could be clearer, but someone has a different sort of ruler at Nissan/Tohatsu. From the inside top of the mounting bracket to the bottom of the cavitation plate my motor is 23 1/4" which is not how these things are marketed. Short is marketed as 15", long as 20", and extra long as 25". I would need the exact measurements of yours. I need an actual 15", not marketed as 15" but really 13 1/4", and so may have to get a marketed as 20" and is really 18 1/4". My wife says men measure things this way all the time, but as I pointed out, in this case shorter than promoted will not necessarily lead to satisfaction. Disappointment and won't work at all are two different things.
James
