rcl700
- Jul 8, 2008
- 161
Okay I posted earlyer that I had found water in the lower unit of the motor I had traded.
well I drained the water/oil out an flushed with oil then refilled unit.
well I ran the motor at the lake a few days ago to test the lower unit. It worked but now checking the oil there was water in it agin.
soooooooo I guess eather the prop seal is bad or the prop shaft is bent.
If the shaft is bent does the lower unit have to be replaced?
can the prop shaft seal be relaced at home?
any help would be great.
