Re: Honda 30 Hp 4 stroke only does 7 mph
A scratch would be best. But you could try a permanent marker at first and see it that works
Do you have a tachometer on your boat? If you have a spun prop, the motor will have a high rpm. In your first post, you say you are not increasing rpms. I am thinking, you could have a carburetor issue. The Honda carburetors have very tiny passages for the fuel to go through. Does the boat sit for more than 2-3 weeks at time without use? When I bought my Honda 50, the dealer said the number one problem with these motors is fuel sitting in the carburetors and clogging them up. He said to either drain the carburetor of run it dry if the motor was not going to be used in 2-3 weeks.
