intrepidvoyager
- Mar 24, 2009
- 216
I am helping a friend with some issues on his Honda 90. Hard starting due to cable corrosion in the selector switch ..FIXED ..now noticed water dripping on starter ......was leak in the water temp sender on the starboard side of the block ...FIXED ....thought we had everything done ...then noticed water pooling at base of starter ...... not coming from above .....also he's also gone thru one starter on this engine ( port).... had a look at it ...massive corrosion inside the planitary gears and the motor itself ....... As the flywheel/starter are enclosed in the mounting plate ...the question is ...where is the water coming from ??? the boat is a 26 twin engine cat used offshore almost daily ..... no issue with the other (starboard ) engine.
Going to pull the lower cowl monday but wondering if any boby has seen this before ??? Water check / pee tubes work fine ...
Thanks
Thanks
