I Brought a Honda B100-sireal #B100L-17046884,with less then 40hr on it,motor looks new,motor was stored for some years,got motor home,Replace Fuel, Fuel Line,Primer Ball, and Fuel Tank, Spark Plugs,Motor Oil,Lower Oil,in line filter,motor would Start with half Choke,but Idle rough and shut off,Removed Carb,check float measurements good,needle valve look good,Blew Carb out using compress air,Removed Fuel Pump and worked Pump by hand,look to pump the fuel thru good,Put motor on Boat, now the motor Starts with 1 or 2 Pull?s Idles Just right,But when put In gear motor will only go a little above Idle rpm?s maybe 1500rpm max,Pushing a light14ft Alum Boat 5mph, other then the Throttle screw the carb only had one Pilot screw for any Adjustments,Please HELP
