WWPotterOtter
- Sep 24, 2009
- 2
This is a 1999 3.5 HP longshaft with Forward/Neutral. I'm changing the lower unit gear oil using a pump that screws onto the neck of a standard gear oil container. The filler tube ends in a fitting that screws into the lower drain hole. The pump works, all fittings and tube are clear. The upper vent is properly left open.
The old oil seemed to drain out okay, but it looked like less than usual came out. It seems like there's a clog in the lower unit preventing the oil from going in. Pumping just causes back pressure. I also tried pumping into the upper vent hole: same clog. What could this be? How to fix?
The motor ran fine just prior when I was flushing it in a tank for 15 minutes. The gears still shift easily, and the prop turns when starter cord is pulled.
Could the impeller have suddenly failed and is now causing the clog? Just discovered my regular outboard guy has gone out of business.
Thanks!
Thanks!
