My father recently passed away, and left me with a 1985 Honda 2.0hp 4-Stroke that needs a impeller. I am mechanicanically inclinded, but not really familiar with outboard motors. Is the impeller located in the lower tail section of the barrel? Is it easy to replace.
Also I would like to change the oil, and can't find the oil drain plug? I was going to remove the bolt closest to the Fill Hole to see if that was the drain, but figured I'd post here before I did anything.
Its hard working on something your not familiar with, espically without a manual.
The motor was also hard to start and it may be due to lack of use, and stale gas (which I have drained).
Any help would be appreciated.
