charles2955
- Sep 2, 2009
- 1
I have a 1988 Tohatsu 70HP motor. I am having problems with the power tilt and trim not lifting or lowering. The motor runs fine with no binding sounds etc. I broke the pump down, put it back together and used 32W hydraulic fluid to fill the reservoir, put the screw in the manual position and raised and lowered the motor to bleed out air. Still, I can not get it to raise or lower. When reading other answers it seems as if I was supposed to use transmission fluid. Is this correct and what weight? Thanks for any help.
