I bought this motor last year for $700 from a shop mechanic. The first time I changed the lower unit oil it was milky. After I replaced it, I noticed it leaking. I took it to the outboard shop mechanic I bought it from, he charged me $130 for doing a pressure/vacuum test but said he found nothing wrong with it. It still leaked oil, and it still had milk so I decided to try and tackle it myself.
I built my own pressure tester based on plans I found here (using a lower unit fill kit adapter/bike pump) dropped the lower unit into a fishtank and at 5lb's of pressure it bubbled like a fishtank aerator from the impeller housing.
After pulling out the impeller I noticed the water seal was sort of rotten, so I pulled it out.
Under that I saw the rusted bearing. It didn't turn smooth at all, so this is what I'm trying to tackle now.
The bearing is really frozen in there good. I want to take the lower unit and put it in the oven. I have the lower unit completely disassembled except for the shift rod going into the lower unit.
So my question is, how do I disconnect the shift rod at the lower unit?
Thanks in advance!
--toqer
Thanks in advance!
--toqer
