longshanks
- Jun 12, 2006
- 188
2001 Honda BF5. Used 70% as a trolling motor on a 15' aluminum skiff, which weighs around 1000lbs, in fresh water. rest of it's life is spent on a 12' jonboat, primarily for getting from point A to B, running at or near wide open.
I'm using NGK BRP5ES plugs, and getting about 4-6 hours a plug before it fouls and needs to be replaced, in order to start the engine.
I've had all kinds of problems with this engine -- not overly impressed with it. I was under the impression that a small 4-stroke OB would be very useful for me, and when I put in a new plug, it runs just great for the first couple hours, but it has proven to be extremely tempermental. Unless the plug is new, it does not idle smoothly. Last year it mysteriously lost all it's oil. And the permformance of it varies from outing to outing.
I have done a few searches on this topic, and not come up with much yet. Others I have spoken to have vouched for the reliability of this motor, but I'm having bad luck, to the point that I'm considering replacing it with a heavier four stroke twin, but I'd really like to avoid that.
carb adjustments? different plug? or scrap it? Any suggestions?
