Re: 2005 honda 130 hp
Is this thing on an engine stand?Hanging on the boat?Still in a crate?Getting bumped around on a pallet?What?Whatever the circumstances,you will need to get the engine vertical, fill the crankcase with the proper amount of motor oil.Check the gearoil level.You will then need a harness and fuel source and water to the water pickups.Do all that and you are likely ready to run.
