Re: 2006 honda 50 running on 2 cyl
Update, Still not running properly. Carbs are clean,has compression on all cylinders.Sparks on all cylinders. Not running on bottom cylinder.. Had access to new cdi box. Tried it still the same. Im a little stumped. This engine has never run right from day one. Not under warranty anymore. My smart dealer insisted it was a proping problem. also the bottom plug appears to be wet when removed. Fuel not water. I tried spraying gas in bottom cylinder half throttle no response.Ok, any thoughts?
