1997 Honda BF 25 carburetor repair
gator97dwb
I pulled the jets and cleaned them only to realize I don't know how to align them once I put them back in. When looking through the throat at the jet, should you be able to see the orifice (aligned with the flow of air) or does it matter? Shop manual is ordered and on the way but I had the time today so jumped the gun a bit. Thanks for the help.
hondon
Re: 1997 Honda BF 25 carburetor repair
What jets are you trying to figure out?To my recollection you have only the main jet at the side of the nozzle well.Idle lift tube goes with the oring at the top and is a tight fit.The cluster that goes around it is installed with the cone at the bottom.Be really carefull with float levels on this unit.They will kill you.
marquette
what do you mean about the float levels? critical adjustment of float level or that the float valve causes problems?
