Carolina Stevie Ray
- Mar 22, 2009
- 6
My 3cylinder Tohatsu 70 is running poorly - only gets to 2/3's power. I've removed and cleaned carbs and changed plugs. Fuel filter and pump are clean. These are 6 month old plugs, but were pretty fouled - it seems like there's a fine coating of oil all over the engine. Any advice before I start adjusting idle or throttle screws? Can I adjust the rate of oil flow from the oil pump?
Thank you for any help.
