I have a Honda 5hp that cranks with one pull, but gas pours out from a small hole on top of the carb. Any ideas on the problem, thought it might be a float switch? Thanks
Yes ,your needle and seat are not needle and seating.That carb needs to come off and and be inspected and cleaned.Carbs for these units are suprisingly cheap,so you might consider just replaceing it.
