2004 honda 200 hp outboard - 800rpm alarm
Cyproz
whenever i idle in low rpm (800 rpm) a beeping comes on after about 20-30 seconds of idling. it only happens when i go under 800 rpm. can anyone help me find out what the alarm/beep means?
gss036
Re: 2004 honda 200 hp outboard - 800rpm alarm
Check your oil to see if it is full and watch your tell-tale to see if it is putting out sufficent water flow. Oil and overheat are probably the only 2 alarms on the engine. What are the lights on the key switch panel showing?
