Hello. I'm usually over in the J/E section, but came across a used Honda on ebay. Seller states: "I had this motor on my boston whaler i hit something and broke a piece off the lower case. The motor still works fine but a little piece is missing. someone told me that a piece could be welded on it but i don't know, you may need to replace the lower casing.
the motor works fine and has the controls, cables and ignition.staneless steel prop."
After seeing the pics, it's a nice chunk missing. My question mainly is would anyone know if a lower unit from a Model BF 50 fit this particular engine? I am waiting to hear back if he has a model # for it, all he says right now is it's a mid to upper 90's 45hp. I've always liked these motors, and it's actually close enough where I could go pick it up, but I don't want to be buying something without knowing a little more about it, or at least knowing what/how much it's going to take to fix it, or replace the lower unit.
Any help would be appreciated. Any chance hitting something and doing this kind of damage to the LU has done other damage elsewhere? I've hit some things pretty hard with my Johnson, but have never done this kind of damage.
Thanks in advance for any info/thoughts on it.
