Troutboy NZ
- Apr 24, 2007
- 32
Hello from New Zealand!
I was having problem with saltwater deposits getting into the lower cylinder and after replacing the head gasket (looked fine!) was still getting water in there - not much at all, but you could definatley see the lower plug was cleaner than the rest and once cooled, salt droplets would form on the ceramic.
I pulled the exhaust cover and the inner gasket looks like this! I think this is where the water was getting in??!!! It did not look like it had actually broken through the gasket, but was surely loosing the seal due to the burning of the gasket!?? This engine has only done about 50 hours.
What would cause this and do you think this would be the likely cause of water intrusion into the lower cylinder? I have reasembled with new gaskets and scraped off the old gasket residue as best I could with wet and dry sandpaper and a very careful blade. All cylinders look clean as a whistle with no corrosion at all.
