Re: 15 horse honda motor stalls while idle
Fuel issue, add some SeaFoam to your gas. Start out double the rate of what is reccomended, then go to reccommended amount. What I did last month, after draining the carb, was take the fuel line loose where it comes out of the fuel pump, put straight carb cleaner in the line, reconnect and then prime the engine, let it sit a few minutes to soak and then start the engine on muffs and hopefully it will run better.
