I had the lower unit off and impeller appears to be ok. When I run the unit in a tank the water doesn't appear to pump up to the engine, but it is pumping water into the casing and the water runs out the 4 drain holes in the front of the lower unit. Could there be a problem with the seal between the top of the pump housing and the pipe that it pumps the water into? If so, is there an easy way to tell if that's the problem? How tight is that connection supposed to be?
