50hp honda propeller shaft holder removal.
tee0157
I have removed the gear case end nut. can the propeller shaft holder be removed without removing the shaft?
chevyjet
Re: 50hp honda propeller shaft holder removal.
You should be able to just pull on the shaft, but you will have to take the oil plug out so that air can get in, sometimes if there is a lock ring/washer under that nut it can get caught in the threads, make sure you get out first, a slide hammer puller would be the next step.
