2000 Nissan (NS25C3) losing power
BassNBob
My 25HP motor is losing power as the day goes on. What could be causing this? Just had a water pump installed and is doesn't seam to be peeing good as it should also. What could be stopping it up?
TOHATSU GURU
Re: 2000 Nissan (NS25C3) losing power
You have to troubleshoot the engine to determine what is wrong with it. Your water pump problem could be as simple as a clog in the pee tube...Or it might be anything in the cooling system. Again, troubleshooting the engine is the only way to determine the cause.
