I have a 2002 Honda BF225 outboard engine. The high-pressure fuel filter keeps getting clogged with white stuff.
I'm already running both a Racor 10-micron and 2-micron fuel filter (new), but it appears the 10% ethanol gasonline is dissolving aluminum oxidation/corrosion from our aluminum fuel tank (or something bad) through both filters and into the engine where it clogs the high-pressure fuel filter (which must be 1-micron or less).
Research is pointing to a few solutions: (1) pay about $675 to have our aluminum tank and the fuel polished (call Roy @ Fuel Oil & Polishing, San Diego, CA); (2) replace the high-pressure fuel filter; (3) rebuild/clean the vapor separator; and, MAYBE, (4) install an easily replacable 1-micron (or smaller) in-line fuel filter before the engine to save the labor of changing the HP fuel filter.
1. Is anyone else having problems with their high-pressure fuel filter clogging?
2. Has anyone seen this type of white stuff in their HP fuel filter?
3. Is anyone else having problems with ethanol fuel dissolving contaminants?
