honda bf90 power trim
gcuthell
Can anyone tell me where the power trim relay is located?
Is it in the SHOWA power unit?
zzzzz
Re: honda bf90 power trim
it's mounted on the powerhead on a bracket:cool:
gcuthell
Thank you. Ifound the unit and call my dealer for a price.
He said the the unit( two relays) would cost $223.
isn't that a lot of money for a trim motor relay?
hondon
Why are you so certain that you require the relay unit and maybe have another related problem like poor ground?What is this unit not doing that you want it to do?Has anyone tried 12 volt direct to the tilt motor to see if it then operates?
