Honda BF 2 Water Intake
brisul
I recently got a mid 90's Honda BF 2 from a friend and it starts fine, but no water comes out of the Water Check Hole. I was wondering what could be the problem... I cleaned the water intake and found it was clogged with some rubber , so I cleaned it out, but no water comes out of it still. Is there some tube that could be damaged inside shaft because I tried opening it, but it seems wedged in. So any help would be appreciated!
Bamby
Re: Honda BF 2 Water Intake
Those bits of rubber are probably your impeller ( water pump) I'd check it before I ran it more. Probably find posts on here on how to do it.
Gregg
brisul
Yup that was the problem. The motor was old enough that the impeller was completely gone. Thanks a lot!:D
