Nissan 9.9B, can't get lower unit off
flatbedjon
I have a Nissan 2 stroke 9.9 hp that is not pumping water to the engine. I just ordered an impeller kit but, can't get the lower unit down. It doesn't seperate at all. It's not the shift linkage as I've already disconnected that. I've tried a rubber mallet but, no go. Don't want to get too forcefull as it is all aluminum down there. Any ideas?
TOHATSU GURU
Re: Nissan 9.9B, can't get lower unit off
Sometimes the drive shaft gets stuck into the crank shaft. Time, prayer and luck to get it to drop.
