Tohatsu 9.8 Fuel Starvation?
Aussiemade
I have a newer Tohatsu 9.8. The engine starts first time and runs great at low revs when cruising around the harbor. When I go to higher revs to get on a plane the engine will sometimes starve and run very rough. If I pump the bulb the engine starts to run great then slowly goes back to rough after a 100 yds or so. It does not do this everytime say 2 out of 3 trips. I can't see any cracks, etc on the fuel hose. Often when pumping the bulb prior to starting the bulb does not get as firm as I would believe it should. Fuel tank vent works and is clear. Any ideas? Thanks, Aussiemade
TOHATSU GURU
Re: Tohatsu 9.8 Fuel Starvation?
Sounds like a fuel system issue. Look for a problem from the tank to the carb.
NJS0930
This happened to my Tohatsu 9.8. Changed the fuel filter under the bonnet and cleaned up the boat's fuel systems as well, and installed a fuel/water separator, and all has been well ever since.
