HI,
My boyfriend owns a small 4 stroke honda outboard. Whe he purchased it, it ran fine, then he got some rope tangled in the prop and stalled it out. After that it has run very rough. It will stall at idle and will only run with the choke. He changed the gas and cleaned the plugs, it starts on the first or second pull most of the time. Can anybody give me a clue as to what we can do to fix this, other than taking it to a dealer? Seems to also bog out when you give it gas in Neutral? Any ideas?
Thanks,
Heather
Thanks,
Heather
