Trouble Starting a Honda 200 HP
jhadley21
I have a honda 200 hp four stroke with fuel injection. When I try to start the engine, the motor just makes a humming noise from what I assume is the cylinoid (spelling?) near the starter. The battery light on the engine check system near the ignition stay on after I try to crank it. I just changed the batteries and they are holding a full charge. I am not sure where to go from here. Any help would be appreciated!
cp
Re: Trouble Starting a Honda 200 HP
Check to make sure that all connections between the batteries and the motor are clean and tight and also that the connections between the batteries, ignition switch and starter solenoid are clean and tight. Good luck.
JUSTINTIME
sounds like the stater relay
you need to do a voltage drop test
