Lock and Dam13
- Aug 9, 2007
- 2
I have a 1992 15hp short shaft/tiller Nissan outboard which for the most part always runs strong and starts right up. For some reason the other day while cruising along the motor came to a slow and steady stop- it sounded almost like the fuel line was pulled away from the motor. I tried starting back up and nothing. Again nothing. Finally after using the choke I was able to get the motor to idle at a somewhat high speed- however within a few seconds it slowed and came to a steady stop. This time it never started back up. I feel like I checked the obvious (spark plugs, fuel line/tank, etc.). Does this sound like something that I need to clean out the carb. since it is an older model? Not sure of what to do next. Any suggestions................anyone? Eager to get back on the water. Matt
