soak 'n fused
- May 31, 2006
- 53
Hello all- I recently bought one of those adapter kits from iboats for changing the lower unit gear oil on my 1990 90 HP Nissan outboard. Well I let my buddy use it to change his Mercury outboard and said it worked fine. When I went to do my boat I could not get the adapter to thread into my fill hole. Is it possible that this is a metric plug? The kit adapter seems a little big to screw into the hole. Now I still have the problem of changing oil. Does anyone know of another way to do this procedure. It is impossible to fill with those little squeeze bottles. Even if you are lucky enough to get a flow going as soon as you empty a tube you have to pull it out and you lose everything you put in. I have been racking my brain trying to figure this out. They say you cant fill from the top because you will get an air leak. HELP!!!!!!
