Converting a honda side control to a johnson top control
psrome
Hello,
I am buying a new pontoon but want to keep my 1995 75 Honda off of my old pontoon. Problem is that the honda is currently a side control and the new boat has a 2003 50 hp johnson 4-stroke with a top control. Does anybody know if I can switch the outboards without changing the controls?
Thank you.
JB
Re: Converting a honda side control to a johnson top control
Howdy, psrome.
Welcome aboard. :)
Very unlikely that the Johnson controls, etc would work with the Honda.
I suggest that you get a Honda binnacle (top) control and transfer everything else from your old 'toon.
psrome
What are the differences from one control to another? Isn't it just forward, reverse, and trim & tilt? Also, if I do buy new or use the existing one can I use the existing cables? I am very new to this and just trying to get my bearings and know what to look for when I go to purchase.
Thanks.
JB
The travel of the throttle and gearcase controls are surely different, the wiring harness will not match, and the control cable ends will probably not match.
psrome
Thank you for the help JB.
How are universal controls able adapt?
