OBMD said:Remove the fuel pump mounting bolts. Have your assistant pump the primer bulb. Look for fuel leakage around the plunger. If no leaks found, continue pumping the primer bulb and depress the plunger, and look for leaks. If no leaks found, you have another problem. Make sure the thermostat is not stuck open.
