Tension screw on Honda 8
pnwguy
Purchased used Honda 8 ( '94 ) and previous owner had adusted the steering tension screw to wide open. He had an ez-steer system connected to main and wanted free range of motion. I have tried to adjust this screw ( to create tension ) I cannot get it to budge. Anyone have similar problems that can offer advise?
Thanks
deejaycee_2000
Re: Tension screw on Honda 8
Is the tension screw stuck or stripped ... you can drill it out, tap it out and put a new one in there ....
deejaycee_2000
Can't you get a spanner or powerbar in there and force it to turn? Otherwise if not, simply drill it out, or use a easy-out, and put a new tention screw in its place ....
