Store Links Mobile - Shop Now
1 of 2 < >
SITE MAINTENANCE
The iBoats Forums will be down for maintenance starting at 1 PM MST on 12/16/2017. The estimated amount of downtime is 3 hours. Thanks for being a part of the iBoats community!
2 of 2 < >
See more
See less
How to check oil level in 2 HP four stroke Honda
  • How to check oil level in 2 HP four stroke Honda
    Can someone tell me where the oil level is to be on a 2 HP Honda 4 stroke? What position is the motor to be in when checking? What is the oil capacity? All I find is a fill & drain, no dip stick. Is the oil to be up to the top of the fill when engine is upright?Thanks
    Re: How to check oil level in 2 HP four stroke Honda
    there is a glass sight level on port side of engine...BF2A holds 0.42qt...BF2D holds 0.26qt...check level in vertical position
    • #3
      So just as long as you see oil in the glass your good to go?thanks
      • #4
        Well - I just looked in the owners manual from a 2hp in the showroom and it says full is to the bottom of the center hole visible in the metal behind the glass
