Re: Shaft seal replacement - 1992 Tohatsu 5hp
Thanks for the response, Elvin. Mine are definitely not sliding off. I removed the punch pin, took off what I assume would be the clutch dog, but other than a a very small bit of free play the gears don't want to slide. I tried a light bit of persuasion w/ a rubber mallet, but no luck. Are they pressed on when manufactured? I found your online sight - will probably order a service manual on Monday.<br />Tom
