Re: Honda 130 cooling
Agree with BF130 - you've most likely got a clogged tell-tale.<br /><br />The first simple thing to try is to push something thin up into the opening to dislodge any clog that might be right there; some use a piece of wire, but I find the perfect thing is an old plastic spray tube like used on a can of WD-40. The plastic tube is the right diameter and, being plastic, is flexible and won't puncture anything.<br /><br />If working that tube in and out of the pee-hole opening doesn't result in a stronger stream of water, then you'll have to go under the cowling and start taking stuff apart. Pay especially close attention to the tee fittings in the line since scale tends to build up there. A good blow with compressed air should get most of it out, but you may need to probe into the tees to break loose any built-up stuff. Be careful to securely put everything back together - you don't want a hose coming off a tee and filling under your cowling with water.<br /><br />Good luck.
