My 2001 Honda 90 started over temp on higher rpm's today. The water stream is not full out and sometimes stops at higher rpms, which i assume means that I have to replace/repair the water pump and/or impeller.<br /><br />Any one out there done this and is it ok to do if you are fairly mechanical? Also, are there any tricks to replacement and other things I should do while I am in there?<br /><br />I also replaced my lower unit oil or I should say sludge last week. Water has gotten in, so do I need to replace the lower seal or is there an upper one that might be giving me both problems.<br /><br />I have around 1900 hours on my motor and not had any problems w/ the pump. I run a charter which accounts for the higher hours.
