2004 Honda BF50
d.a.l
Hey all, this has been the first weekend that I have run her full out and I have found that the stock 11 1/4x13 prop, WOT, will run about 6500 rpm. I stopped at 6000rpm and figure I had about another 1/2" to go. A Honda marina sugested a 10"x16 pitch alu. prop to lower the rpm's. I tried a 11 1/8x14 and it lowered the WOT to 6000rpms but that was with full trim down. When I trimed the motor up , even a little, it started to climb over 6000 again. One solution I thought was to use the stock prop and put a stop on the throttle to prevent possible over reving? Would it harm the engine any to just never run it full throttle (or the last inch of it) or will that effect the HP output? The large plate (cavitaion?), just above the prop is exactly even with the bottom of the boat and the motor is in it's lowest mounting position. The boat is a KMV 480, a 16' fiberglass center console, 800 lbs empty with an average load of 350 lbs. of people and gear. Does the 16 pitch sound to agressive? Any help or advise would be appreciated. Don
JB
Re: 2004 Honda BF50
I would try a 15" before trying a 16", d.a.l.<br /><br />Good luck. :)
scotty c
Re: 2004 Honda BF50
i am running the same prop as your stock one<br />11-1/4 x 13 on my BF50.<br />I can do about 30 mph at 6000 rpm's, and there <br />is some throttle left, but i don't wanna push it<br />past red line.<br /><br />let me know how you do with a different pitch<br /><br />I am running a 16' boat also<br /><br />Thanks
JimCobb
Re: 2004 Honda BF50
For comparison, am running 2004 bf-40 with <br />11 3/8 x 14 on 16' Aluminum Triton.<br />wot gets 33 mph at 5900
d.a.l
Re: 2004 Honda BF50
I'm picking up the prop this weekend so I'll let you guys know how it works out.<br />Cheers, Don
