Honda 90 hp trim problem: engine pulls out of water
cdelisle
Hi, I am having a problem with my 96 honda 90hp 4 stroke. When i get underway the engine trims out of the water. It seems to be a trim problem but the switch on the throttle is fine, it doesnt appear to stick. Does anyone have any ideas. Thanks so much.
robards
Re: Honda 90 hp trim problem: engine pulls out of water
The first thing I would do with a friend is find the wire under the console that feeds the PT&T switch and disconnect it when it happens. Sometimes the switch doesn't look like it's sticking and it may be internally. If that doesn't work I would do the same for the one on the motor.
