Honda BF8a Lower Unit removal-dead end
Bapper23
I read Hondon's response to bprender on 3/27/05 but I'm having trouble identifying components. I<br />think I removed the neutral safety switch and the<br />bolt that retains the shield. Not sure where the <br />bolt that retains the "shift clevis"? is. I removed the only other bolt I saw on the shift <br />rod and couldn't remove the shifter. Also removed<br />the 'u'shaped thing that moves when you turn the<br />throttle but the washer and the silverish cylinder<br />fell down a nearby hole. Not sure how to retrieve<br />it. I can e-mail photos if anyone can help.<br />Thanks, Rich (Bapper23@aol.com)
